Z Fire Posted February 6, 2013 Share Posted February 6, 2013 I am in the process of assembling a L28 stroker motor. I do have new Eagle H- rods which do not have the cylinder wall oiling hole in the shoulder of the rod. What is better, drill the hole and potentially weaken the rods or do nothing and be without the extra lubrication ? All stock rods I have seen do have them. Any advice and experience feedback would be appreciated. Quote Link to comment Share on other sites More sharing options...
PMC raceengines Posted February 7, 2013 Share Posted February 7, 2013 Do not drill the rods ,,,, repeat DO NOT . There is no need to oil the bore , there is lots off oil splash from the crank . i run many rods with no oil hole in L motors , Quote Link to comment Share on other sites More sharing options...
josh817 Posted February 7, 2013 Share Posted February 7, 2013 There is a thread floating around discussing oil squirters for the underside of the pistons if you so desire. One of those how to modify your L engine books says to remove the oil bump on the side of a stock rod because there is too much oil getting up there... I suppose in race conditions.I removed my oil bump when balancing and polishing my rods. Ran just fine before I had the sudden desire to take it all apart. Quote Link to comment Share on other sites More sharing options...
Z Fire Posted February 8, 2013 Author Share Posted February 8, 2013 Thank you guys for your feedback. I am good now and will not make the holes. Quote Link to comment Share on other sites More sharing options...
