str8pipez Posted March 7, 2013 Share Posted March 7, 2013 I'm installing coilovers on my 75 280 and I'm about to start the rear and had a question. Should I put front insulators in the back while I have it apart to get more room for drop or incase I add camber plates in the front? I'd rather only do this once. I already forgot to add the washer above the T3 top hat and have to remove the fronts to put them back in. Nothing like doing things twice. Quote Link to comment Share on other sites More sharing options...
str8pipez Posted March 7, 2013 Author Share Posted March 7, 2013 Now that I think about it I may as well put the fronts in the rear and add the camber plates. $40 difference for camber plates from T3. Quote Link to comment Share on other sites More sharing options...
Poundz9oh9 Posted March 7, 2013 Share Posted March 7, 2013 Good choice .. I did it twice .. I originally left all the original insulators in place onall 4 corners, but I didn't like the range of the drop in the rear, so I picked up some camber plates for the front and moved the front insulators to the rear. Lesson learned, good thing it wasn't major work as it only took about a half hour. Quote Link to comment Share on other sites More sharing options...
str8pipez Posted March 7, 2013 Author Share Posted March 7, 2013 Did you use weld in or bolt in camber plates? Quote Link to comment Share on other sites More sharing options...
Poundz9oh9 Posted March 27, 2013 Share Posted March 27, 2013 I personally went with the Ground Control bolt in plates because I don't have the equipment/know how to weld anything in. However, I'll more than likely re-do them with some weld ins in a year or two. I want it my towers too have more of a "stock" flush look .... Quote Link to comment Share on other sites More sharing options...
