Advice on cutting OE springs .
Ok , i just finished my LS1 swap , 78 280 Z . Now , with new wheels and tires are mounted , i'm ready to move on to suspension mod. .
Questions are for those who cut their OE springs :
I was thinking of cutting 1/2 a coil in the rear , that should give me the look that i'm shooting for .
And the front , i need at least 2 in. lower . For those who cut 1 coil off , i need to know how much lower and ride quality ?
I have done this , cut a coil off , before on my 83 ZX ( LS1 and 6 spd. ) . Got the look i wanted but the ride is a little too harsh for me .
Any inputs or other options will be appreciated . Don't want to do coilover at this time . Thanks
One suggestion for the rear is to swap out the strut insulators with units from a 240Z....easy to find a used pair cheap.  They are shorter than the 280 units, and that change alone will drop your rear ride height 1-1.5 inches.  Much better than chopping your springs.
Sorry....don't have an easy answer for the front.  Many people will tell you to just bite the bullet and install different (i.e. shorter/stiffer) springs.  Fortunately, they are plentiful, and cheap if you buy used.
Good luck with it....the ride looks nice, and that LS motor should make it rip.
Just wait until you can do a coilover conversion.  I cut my springs years ago and it made the car undriveable.  Every seam in the road bottomed out the suspension.  I would discourage you from cutting stock springs-the suspension bottoming will drive you crazy and it even cracked my roof at the b-pillar.  If you leave your suspension alone, you can enjoy your new engine, but if you cut your springs, you will have to baby the car everywhere you go-that would be a shame.
Actually the rear is not so bad . Would like the rear to be a little stiffer . I'm very happy with rear on 83 ZX , by cutting a coil it helps the car from squatting too much during launch . Since the LS1 motor is a little lighter , i don't need it to be very stiff up front . I might just cut half and go from there . Just need to know how low will i get with half cut off . Don't think i will get 2 inches that i'm looking for up front . Might have to lower the spring seats . Thanks the above for your inputs .
The previous owner of my 260z had aftermarket springs installed on my car all the way around. I replaced the front strut inserts on it later on and cut a coil out of the front springs. I figured that would drop the front enough, Nope. It was still real high in the front so i then cut another coil out of them. That got it to an acceptable height, the front bounces a little bit but the ride is not harsh.
These were stock aftermarket replacement springs though.
So , you cut a total of two coils . How much lower , in inches , did you get ?
  • 2 months later...
