HowlerMonkey Posted October 18, 2013 Share Posted October 18, 2013 If you plan to swap crossmembers with a 280zx, remember to consider they type of sump required for each crossmember. Quote Link to comment Share on other sites More sharing options...
ArchetypeDatsun Posted December 4, 2013 Author Share Posted December 4, 2013 Well seems my head gasket is bad at start up I'm getting tons of white smoke and smells like antifreeze I confirmed it when I drove the car to work for 2 days and the antifreeze was getting lower in the radiator so as of now it's sitting and thinking if I really should throw money at the L24E or just swap in another engine I'm debating L28, fix up the L24E or go balls out and do the rack and pinion with the 280zx crossmember and steering column and RB swap. If any old members still active that had there 810's could chime in would totally help as I'm pretty much lost since 810's are rarely modified. Quote Link to comment Share on other sites More sharing options...
ram75280z Posted December 11, 2013 Share Posted December 11, 2013 That's too bad about the head gasket. If it were mine, I would build the l24. You could pretty easily make200hp using all period Datsun parts. Although a small cam, 270 or less, would be a good idea. It's easier to make more hp per liter with the l24 & l26 because all the stock intake manifolds are too restrictive for the l28 to peak at even 6000rpm. Whereas a late model 280zx FI intake can make the l24 peak at 6500rpm. Quote Link to comment Share on other sites More sharing options...
ArchetypeDatsun Posted December 12, 2013 Author Share Posted December 12, 2013 Yeah that's what I want to do my second choice would be a RB swap if I get bored but that's when I have the money for that. I have been looking for a 280z intake manifold and probably have the head done at a shop or send it to Rebello. Quote Link to comment Share on other sites More sharing options...
