Ben's Z Posted May 6, 2013 Author Share Posted May 6, 2013 Did it start after you jumped the fuel pump relay , getting spark or inj. pulse ? No, my fuel rail is not done. Need to located some NPT taps tomorrow. Quote Link to comment Share on other sites More sharing options...
Domzs Posted May 6, 2013 Share Posted May 6, 2013 I'd rec. you to finished mounting and connecting everything together first before you go any further . I've seen , too often , that when a tech try to start the motor when the job is not completely done . And when it doesn't start , usually due incomplete connections or ground wires not mounted Quote Link to comment Share on other sites More sharing options...
Ben's Z Posted May 6, 2013 Author Share Posted May 6, 2013 Man, I just want the fuel pump to prime and the ECCS light to come on... Quote Link to comment Share on other sites More sharing options...
Ben's Z Posted May 6, 2013 Author Share Posted May 6, 2013 I think where I am held up is the blue and red wire on the fuel pump relay. I have the other side of the 6 prong plug and (not at the car at the moment) goes to the ECCS pin 16, I am not getting power to ECCS I think. Quote Link to comment Share on other sites More sharing options...
Domzs Posted May 6, 2013 Share Posted May 6, 2013 Man, I just want the fuel pump to prime and the ECCS light to come on... I feel your pain . LOL Quote Link to comment Share on other sites More sharing options...
Ben's Z Posted May 6, 2013 Author Share Posted May 6, 2013 (edited) Here is my 280z ignition harness. Wiring is as follows: Red: The colored schematic looked like it required a wire to branch off of the 12volt constant for fuel pump relay to ignition switch, so I tried this... Yellow: to yellow and white striped wire on zxt harness Black:(next to yellow wire) to ignitor/distributor condensor Black: 6 prong plug to ignition relay Edited May 6, 2013 by Ben's Z Quote Link to comment Share on other sites More sharing options...
Ben's Z Posted May 6, 2013 Author Share Posted May 6, 2013 (Will solder when it ever runs) 280zxt female harness Green and black to ground Yellow w/white stripe to 280z female ignition plug recepticle that has black w/yellow stripe to ignition switch Yellow wire to coil Quote Link to comment Share on other sites More sharing options...
Ben's Z Posted May 6, 2013 Author Share Posted May 6, 2013 Am I close? Quote Link to comment Share on other sites More sharing options...
Ben's Z Posted May 6, 2013 Author Share Posted May 6, 2013 I don't have a fuel pump control module. Do I use the plug underneath the dash where it should plug in to wire another fuel pump relay? What purpose would the existing fuel pump relay serve at that point? Quote Link to comment Share on other sites More sharing options...
Domzs Posted May 6, 2013 Share Posted May 6, 2013 I can youi just give power and ground to your ECM ( where they're supposed to be ) and see if you get the result that you are looking for , at least the green light . Quote Link to comment Share on other sites More sharing options...
cgsheen Posted May 9, 2013 Share Posted May 9, 2013 I don't have a fuel pump control module. Do I use the plug underneath the dash where it should plug in to wire another fuel pump relay? What purpose would the existing fuel pump relay serve at that point? You don't need one. Not having one will NOT keep you from starting or running the engine once you get everything else wired correctly. From the pictures above (hard to tell, BUT) I don't think you have everything else wired correctly... Quote Link to comment Share on other sites More sharing options...
