Gas Odor Inside 72 240Z
Miles
My 280 will not run for any lengthy period without the gas cap loose and sucking air which is most likely due to a plugged vapor tank or lines.If you plug them make adequete ventilation for the gas tank. Mine sucks air and also blows air like a fat man going up a hill.I have removed or disconnected the vapor lines on 620 Pick -ups and vented the gas tanks via the gas caps with no ill effects
There is a strong gas oder inside my stock 240Z. I inspected the vaper/expansion tank and hoses in the rear of the car. All hoses are new and secured to the tank fittings. I was gong to plug the lines but noticed that there is what appears to be a fuel return line from the engine comaprtment attached to the expansion tank. Is that small line from the engine to the expansion tank a vaper line or a fuel line? Can I plug all of these line without effecting engine performance?
