skirkland1980 Posted May 14, 2013 Share Posted May 14, 2013 I'm getting a misfire at about 5500 rpm under load at 17psi boost. All specs are in my sig. I thought it may be spark blowout so I pulled the spark plugs and rechecked the gap. I have 0.030". Are there other things that could be causing spark blowout or could it be a problem with my ignition system? The plugs are NGK BPR7ES using MS2 V3.0 firing a single coil. Thanks. Quote Link to comment Share on other sites More sharing options...
Domzs Posted May 15, 2013 Share Posted May 15, 2013 It could be a weak ignition sytem like a weak coil and lean condition also causes misfired . Most likely , you have a lean misfired condtion . Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted May 15, 2013 Author Share Posted May 15, 2013 I'm thinking it's got to be a spark misfire because I'm holding 11.5 afr and it backfires through the exhaust. Quote Link to comment Share on other sites More sharing options...
Domzs Posted May 15, 2013 Share Posted May 15, 2013 It could be the ignition . Can you get O2 reading with your setup ? Quote Link to comment Share on other sites More sharing options...
Nelatl Posted June 29, 2013 Share Posted June 29, 2013 Did you ever solve this problem? I'm suffering from the same problem at 15psi. What part of Ga are you in? Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted July 2, 2013 Author Share Posted July 2, 2013 Not yet. I think my distributor is bad now. I'm swapping it out tonight. I'm in stockbridge. Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted July 3, 2013 Author Share Posted July 3, 2013 Well the distributor was bad. I have to completely retune now. Once I do I'll update with the fix. Quote Link to comment Share on other sites More sharing options...
Nelatl Posted July 3, 2013 Share Posted July 3, 2013 I changed my plugs and closed the gap to .028 and now no more problems We should try to meet up sometime. There is a classic Japanese meet every third Sunday of the month in Dunwoody. Good luck with the dizzy. Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted July 4, 2013 Author Share Posted July 4, 2013 On 7/3/2013 at 3:15 AM, Nelatl said: I changed my plugs and closed the gap to .028 and now no more problems We should try to meet up sometime. There is a classic Japanese meet every third Sunday of the month in Dunwoody. Good luck with the dizzy. We could do that or sometime sooner. What part of town are you in? Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted July 13, 2013 Author Share Posted July 13, 2013 I drag raced the car tonight. I replaced the cap, rotor, and spark plugs (BPR7ES). I didn't have a feeler gauge so I just closed the gap a little and the problem is gone. I didn't have the MSD box connected so I was able to fire just fine with the MS coil driver. The engine idles a little rough after the plug change now with the tighter gap. Anyone have this problem? Otherwise the car has never run better. Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted July 13, 2013 Author Share Posted July 13, 2013 Here is a video. Quote Link to comment Share on other sites More sharing options...
Nelatl Posted September 14, 2013 Share Posted September 14, 2013 Nice run! Sorry I didn't realize you replied a while back. It would be great to get a chance to check out your car. I'm in the Roswell area. Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted September 16, 2013 Author Share Posted September 16, 2013 Yeah I'm off on sunday and monday and evenings. I'll be at the drags this friday. Quote Link to comment Share on other sites More sharing options...
Nelatl Posted September 17, 2013 Share Posted September 17, 2013 You going to Z Nationals at Z1? Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted September 17, 2013 Author Share Posted September 17, 2013 I haven't heard of it. Do you have more info? Quote Link to comment Share on other sites More sharing options...
Nelatl Posted September 17, 2013 Share Posted September 17, 2013 Go to Z1Motorsports.com. Click on the Znationals icon and check out the info. This event happens out in Carollton Ga at their shop once a year. I think this is the biggest z event on the East Coast.... I think they said 2000 people last year, I've been the past two years and it keeps getting better. Give me a call if you want. Nelson 404 932-9654 Quote Link to comment Share on other sites More sharing options...
