rb25det obd service plug
zigen9
Hi eveyone, I have done the search about the observed service plug on the event forum. But no luck. Here is my question. I have Whitehead performance wired up a obd plug for me. Wiring is correct. I'm sure because I have double checked. I brought an eBay computer plug.scanner program. Did the whole.procedure correctly. But it doesn't show me anything. Anyone can tell me which scanner I should use that will work?? I really need it asap. Any help.would.be much appreciated
The program I have is tecu. But it doesn't work. There is also another program in the same CD. But it doesn't work either.
Domzs: is that blazt you mention free??
Loy: where did your friend got his consult??
Thanks for reply. I have purchased NDS1 to do diagnostic. It works fine when it's freeware, meaning I can use the program when I turn on my car, even start up my car. BUT after I purchased (activated the program), It works when I turn on my car, but not start up my car. Anyone knows what's going on??
  • 9 months later...
