Timing
Guest snipes_uk
Guest snipes_uk
After replacing my headgasket and having to fit the timing chain tensioner again i'm not sure if the timing is right. the engine idles but will not rev. unfortunatly the shiny links are missing from my timing chain so I cant use them as a guide. pretty sure the oil pump/dist are back the same. Car was running good before.
Thanks, Wes
Turn your engine to TDC, then look through the cam gear to the first tower. There should be a notch on the gear that lines up with an arc on the tower, indicating proper cam timing. If they don't line up, you know it's off, and you will need to pull the gear and move it a tooth forward or back. Good luck.
