ktm Posted May 29, 2013 Share Posted May 29, 2013 I just wanted to post about a relay kit for the Taurus/Lincoln fans that is currently available for sale on Ebay through the Hollister Road Company. The kit is incredibly well made and includes everything you need to wire up a Taurus/Lincoln fan, including a temperature switch if you are not running a PCM. (Ebay Link: http://www.ebay.com/itm/Lincoln-Mark-VIII-2-Speed-Fan-Relay-Kit-/111007164874?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item19d88ae9ca) The Ebay link photo does not do the kit justice. The kit costs $90 and includes 3 high amp relays, one (1) 50 amp fuse in a water tight connector (large on in the photo), one (1) 7.5 amp fuse (for the ignition hot wire going to the relays) in a weather pack connector, 10 ga wires for the fan power feeds and ground, a temperature switch for 2 speeds. The power and PCM control wires are sufficiently long to allow you to mount the relays just about anywhere except inside the car (the power wires are the limitation). I can't recommend this kit enough. Sure, you can source your own relays, fuses and wires, as well as spend a couple hours wiring everything up correctly, but you'll spend almost as much money as this kit and it most likely won't be as "professional" looking. I hope this helps someone who is looking to do this install at some time. Quote Link to comment Share on other sites More sharing options...
Domzs Posted May 29, 2013 Share Posted May 29, 2013 It's a fair price and will save some labor time . Looks good . Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted May 29, 2013 Share Posted May 29, 2013 Nice set up, may just look into picking one up. Quote Link to comment Share on other sites More sharing options...
Old Man Posted June 3, 2013 Share Posted June 3, 2013 Helped Me! Answered my stock fuel rail question. Quote Link to comment Share on other sites More sharing options...
Drewz75t Posted June 4, 2013 Share Posted June 4, 2013 Great product. I've been running mine for 2 years with no problems. Quote Link to comment Share on other sites More sharing options...
