HEI too big?
Hey guys, starting to pick up parts for my v8 swap in my 79 280zx, and I was wondering, I have a 400hp carbed 355 with an hei distributor........   Is it worth buying the smaller style msd dist for space or will I have enough room with the hei?  Pics would be great too......  Thanks for your input
There is something wrong with that attached thumbnail.  It appears to be a scarab type installation wherein the rear of the engine is 8 inches from the firewall.  The JTR installation puts the engine further back such that installation or removal of the distributor becomes questionable.
The distributor did not free up that space.  Its the fact the engine is mounted so far forward and not in the "JTR" position.
Here is what the very small MSD (8570) looks like when its in the JTR position (PLUS another 1/2 ich further back).
Chevy made small body distritubors for the 80s and 90s TBI and TPI engines.
You can pick them up used at wrecking yards for 30 bucks and experiment.
Though designed to work with an ecu, you might be able to modify some harnessing and use components commonly found at the wrecking yards and use it and I'll bet MSD makes a system that plugs right in.
I'm sure someone has figured out how to do it cheaply but it will take some searching and I'm not sure they ever came with vacuum advance.
You might find that the output from the stator is identical to the one from the HEI or you could go the route of using the ECU from the tbi setup with a map sensor and having a prom burnt that will give you the functionality you desire and possibly more like the ability to control an a/c idle up soleniod or even cut the a/c compressor at your desired rpm/load.
If they made one with a vacuum advance, the easiest route would be to find someone who found a way to use it with the normal HEI electronics but with an external coil.
Lots of options but some are difficult.
