Finally got started
I'm dying for a lift too. I helped a buddy swap a diff the other night using a lift. Actually, that job is easier for me on my back assisted by a floor jack. Dislocated shoulders just can't catch the diff overhead. Took three of us old farts to carry the thing down! That dilutes the beer 3 ways too!
  • Replies 94
I pulled and put my diff back in with the CVs attached, I thought it was gonna kill me. I put it on my lap and then slid under the car and did some pelvic thrusts until I got it started in the moustach bar. I was sore for days!
That can be done with a floor jack.  Been there, done that.
You likely need more practice!
That's for sure!
I tried with a floor jack but couldn't manuever it into place. Kind of a long story but I was fighting a stubborn CV and finally pulled the diff to get it in and wasn't about to take it out to install the diff.
Keith, I'm going to put you on the spot. I know you have had more experience bleeding your clutch than you would like to have had. I've bled the s#!t out of mine and it feels really firm and only get the smallest of bubbles while cracking the screw but it will only disengage the clutch enough to just let it into gear, the wheels still turn with the pedal down(still on stands). I have a Wilwood 7/8" MC and a LS7 clutch. I used a mityvac to get to where I am now and finished with running my bleeder line up above the MC and pulling a vaccum on the bleeder while cracking it and pumping the pedal. I don't know if that makes sense but I feel pretty good about have as much air out of the system as possible. My thought is that the actuator rod is not extended enough. I was thinking about removing the pedal return spring and moving the pedal until I feel a little hydraulic resistance and then adjusting the rod out to a point slightly less than where I feel the resistance. Does that sound like a good idea? I've read about guys blowing out their slave with too much fluid.
Here's another method I use to bleed clutch hyd. . First , I don't like to use vac to bleed clutch or brake sytsem , sometimes it creates a vac ( air ) in the system . If you have problem getting air out of the system due hyd line routing , do a back bleed . Meaning , fill a pump or syringe with fluid then force it up from the bottom ( line that goes to slave ) then bleed it the normal way to make sure you get all the air out . This method works very well when hyd lines or pipes that route too high up or too many loops and turns .
Edited by Domzs
Matt-I wish all you sra guys would post pics from underneath while on a lift. I'm talking to the fella in georgia with the black wheelie-prone ladder bar car. Trying to get together at his track next week. I'm likely looking at a chassis minus engine and tranny.
Naptown-my problem (one of my problems) was lack of pushrod length also (insert favorite Viagra joke), even after bleeding like crazy. Bleed some more in a week to get those tiny bubbles out too. Also, make sure it disengages a little extra or you will grind on high rpm shifting. It has to totally disengage. Anybody know why on jackstands, with the clutch is in, when I push the shifter from neutral into first, the tires rotate a bit? Is that synchros?
I think I finally got my brake bleeding issues taken care of last night. 2 gallons of dot and at least 30 hours later I have a firm pedal. I think I had about the same amount of time building my headers and exhaust! Going to go thru my suspension and driveline tonight torquing bolts and throw the brake lights and wheels on and go for a spin.
Indianapolis Metro Police please stay out of my neighborhood from 8-10pm, thanks.
