Testing in the 280 (video)
Wfritts, good to see you back! I see everybody trying to make a subframe for the diff that tries to re-use the stock mounting hardware. Since you guys can weld, could you not make a strong bracket system that is welded to the bottom of the floorpan and distributes the loads better. This stuff really doesnt need to be bolt-on - I believe that ship sailed back when we cut out our stock tranny mounts out. No turning back.
I just want to keep it easy to remove. As you (should) well know, you WILL be pulling it at some time, for some reason.
I'd just weld in my front mount if it wasnt for that. However, I picked up some 1" square tubing today, and should be able to cobble something together to work. Probably as ratty as the rest of it, but it works!
  • 3 weeks later...
