skirkland1980 Posted July 31, 2013 Share Posted July 31, 2013 (edited) I just got my cam back from delta camshaft. I have a question concerning the new specs of the cam. I measured total lobe height of 1.51" and a width of 1.24". That should equal a lobe lift of .270" @ 0 lash. Multiplied by the rocker ratio of 1.5 equals a gross lift of .405"???? That's a completely stock lift number. I was told lift would be .450". Anyone know whats up? Thanks Edited July 31, 2013 by skirkland1980 Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted July 31, 2013 Author Share Posted July 31, 2013 So I measured lobe lift with a dial indicator. I'm getting .275". I called delta, they said I should have .300". I'm glad that they're going to take care of it. I'm just a little disappointed that they don't check their work before sending an item 2500 miles. Quote Link to comment Share on other sites More sharing options...
Xnke Posted August 1, 2013 Share Posted August 1, 2013 Delta has had problems with that, my 0.480" lift cam was 0.455". They were working with a 1.6 rocker ratio instead of the real 1.48 ratio of Nissan rockers. Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted August 13, 2013 Author Share Posted August 13, 2013 here's a video of the cam lobe measured with a dial indicator. Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted August 13, 2013 Author Share Posted August 13, 2013 here are the rockers that I just checked Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted August 22, 2013 Author Share Posted August 22, 2013 I got the cam back from delta a second time and I'm highly disappointed. I measured lobe lift again with a dial indicator. Lobe lifts range from .306"-.311". I measured every lobe. Should I use this cam? Thanks. Quote Link to comment Share on other sites More sharing options...
Robftw Posted August 22, 2013 Share Posted August 22, 2013 I would call and ask what the deal is, and for a camshaft I would use it. .05 on a cam is tolerable, I believe thats within factory specs Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted August 23, 2013 Author Share Posted August 23, 2013 Thanks. I called Isky and the guy in tech support that I spoke to said it should be ok. Next question, anyone ever 'mix and match' lash pads? Quote Link to comment Share on other sites More sharing options...
Robftw Posted August 23, 2013 Share Posted August 23, 2013 As long as you get the correct wipe pattern on the rocker arm the lash pad size doesn't matter Quote Link to comment Share on other sites More sharing options...
Xnke Posted August 23, 2013 Share Posted August 23, 2013 (edited) My Delta cam has two different lobe sizes...one for intake and one for exhaust. I used two different size lash pads, one size intakes, the other exhausts. I have three Delta regrinds this way, the intake and exhaust lobes aren't the same. They're real close, but not exactly the same lobe profile on the intake and exhaust. Same deal with my Isky custom grind, the intake and exhaust lobes are slightly different, and the cam lobes are phased about a degree and a half from the #1 exhaust lobe to the #6 exhaust lobe. Edited August 23, 2013 by Xnke Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted October 16, 2013 Author Share Posted October 16, 2013 (edited) I finally got my car running after finally mixing and matching a set of rockers that weren't ground wrong Edited October 16, 2013 by skirkland1980 Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted October 16, 2013 Author Share Posted October 16, 2013 it's nearly impossible to post from my cell phone. but here goes. valvetrain is very quiet. its running a kind of rough but I think I just need to retune. just an update to the thread. I have to speak into my cell phone to write this. sorry about punctuation and stuff Quote Link to comment Share on other sites More sharing options...
