Electrical Problems =)
So hello and thanks!
My early 260Z Has some problems i'll give you the specs..
*Stock motor early 4 screw SU's rebuilt by ZTherapy .
*Mallory Unilite Distributor mechanical advance and some old Mallory coil that gets pretty warm when running.
*I added light and turn signal relay kit some time ago.
Everything else is stock.
My problem is the coil is only getting like 9 to 11 volts max sometimes and makes me think i'm no getting good spark.
Also sometimes car will crank fine, but won't spark unless unless I add a Jump box.
What should I do?
Is there a newer better ignition system I should be using that will help clean up and help car run better?
Is there a shop or any one chicago who can help really dig into these car and iron out my issues?
