TurboSE Posted August 25, 2013 Share Posted August 25, 2013 Trying to put my RB25 tranny back on my RB26 and it won't slide all the way in. I can't get them any closer than about 1". I'm using a Giken STR clutch/flywheel. I used a Z32 alignment tool. The clutch slides onto the splines off the motor, so I know that fits. Both the engine and trans are out of the car, on the ground. I've tried it with the trans in neutral and in gear. I've tried lining it up with jacks, blocks of wood, an engine hoist. I don't want to try and pull them together with the bolts, that idea just sounds like a disaster waiting to happen. I've tried a light coating of grease on the input shaft. Any ideas I'm missing? Quote Link to comment Share on other sites More sharing options...
TurboSE Posted August 25, 2013 Author Share Posted August 25, 2013 (edited) I picked up a tranny jack from Harbor Freight, that $80 netted me another 1/4"... could the throw out bearing be resting against the pressure plate and holding me off the last little bit? Edited August 25, 2013 by TurboSE Quote Link to comment Share on other sites More sharing options...
TurboSE Posted August 25, 2013 Author Share Posted August 25, 2013 Got it, 5lb sledge....wooden block....done. Quote Link to comment Share on other sites More sharing options...
Glliw Posted August 25, 2013 Share Posted August 25, 2013 Glad to hear it all worked out for you Quote Link to comment Share on other sites More sharing options...
NewZed Posted August 25, 2013 Share Posted August 25, 2013 The last pieces to fit are the mainshaft tip in to the pilot bushing and the alignment dowels on the back of the engine, I believe. It's also possible to jam the pilot bushing deep in to the crankshaft on some engines, although I don't know if there's an inch of space there. Were you lightly tapping or banging? Seems scary. Quote Link to comment Share on other sites More sharing options...
fast-datsun Posted March 21, 2014 Share Posted March 21, 2014 You throw out bearing sleeve may be wrong... there are different lengths and OS clutches usually call for the shortest one, but the O S instructions give the Nissan part number to use.... Quote Link to comment Share on other sites More sharing options...
