Cam Timming affecting vacum
Joel, call me tonight. Yes cam timing can/will affect idle vacuum depending on the degree to which you adjust it. However, you will be hard pressed to correlate idle vacuum to cam timing. That cam timing will require a degree wheel and a dial indicator.
