Fuel pump specs and coolant flow?
What kind of fuel pump pressure and gph do I need for a Holly 750 w/vacuum secondaries? What about water pumps, how much gph works best and does anyone recommend electric water pumps?
I think the Holley blue pump that comes with the external regulator is plenty - note that it is noisy, so try to isolate it from the car some. I've heard the Carter pumps were quieter.
As far as a water pump, I'm using a Stewart Components piece, as it is supposedly superior to the others since the water flow has been equalized to both sides of the engine - the stock casting is not optimal in this area, supposedly. See the links page for their site.
