Guest bang847 Posted July 11, 2002 Share Posted July 11, 2002 Hey guys.. it been a long time since you heard about work on my project.. I have been getting a bunch of crap from landlord/roomate so i need to get it out quick!!! As some already know I took the head off and bought a JY head to replace it... What happened is I didnt know about wedgeing in a block of wood to hold the tensioner... So i gotta reset to whole thing... . oh well... question is... Do i need to remove the oil pan to get to the timing set? I tried to remove the cover but i seems to be held on to something.. I have removed all the bolts that i can see.. everything on the front and also 4 with the oilpan.. NEED HELP!!! Quote Link to comment Share on other sites More sharing options...
yo2001 Posted July 11, 2002 Share Posted July 11, 2002 a couple of the water pump bolts have to come off I think. It has been awhile. Quote Link to comment Share on other sites More sharing options...
Guest jurven240z Posted July 12, 2002 Share Posted July 12, 2002 Yes, you have to remove at least three water pump bolts. Face the timing cover they are on the left side of the pump. Quote Link to comment Share on other sites More sharing options...
yo2001 Posted July 12, 2002 Share Posted July 12, 2002 How? LY motor needs to be tilted the other way to fit in the car property. Well, at least that's how it was in 70's race Z's. they had to tilt the motor other way and get an aftermarket bell housing to complete the swap. Well, no you don't need to take th oil pan off. be acreful not to tear the oil pan gasket. Quote Link to comment Share on other sites More sharing options...
David K Posted July 12, 2002 Share Posted July 12, 2002 bang, the front cover may be stuck on. be careful taking it off, it is aluminum. Quote Link to comment Share on other sites More sharing options...
Guest bang847 Posted July 12, 2002 Share Posted July 12, 2002 the thing is that the whole thing is loose.. I cut all the silicone gasket to loosen it but there is some thing holding on to it... Am i working a bad angle?? I would take pictures but I no longer have a internet connection.. I only get to read and respond at work... The whole thing is pretty loose.... I can wobble the whole thing.... it just wont come out.. it is fustrating as hell.. Quote Link to comment Share on other sites More sharing options...
Guest LIghtningZ Posted July 12, 2002 Share Posted July 12, 2002 If you still dont get anywhere with get ahold of DAW!!! I know he'll help!!! good dude,!! Quote Link to comment Share on other sites More sharing options...
Guest bang847 Posted July 12, 2002 Share Posted July 12, 2002 I have completely removed the water pump.. I just wobbling it... it is moving about 1 inches side to side?? Quote Link to comment Share on other sites More sharing options...
David K Posted July 13, 2002 Share Posted July 13, 2002 OH YEAH,,,,DOH!!!!! you have to remove the oil pump/distributor shaft to remove the front cover. there is a hole in the cover that holds the shaft. you have to take down the oil pump on the bottom of the motor and the shaft falls right out. 4 12 mm bolts. important to remember which bolt went where cause they are different lengths. you then have to reset the timing. post back when you get to this point. Quote Link to comment Share on other sites More sharing options...
yo2001 Posted July 13, 2002 Share Posted July 13, 2002 Originally posted by David Karey:OH YEAH,,,,DOH!!!!! you have to remove the oil pump/distributor shaft to remove the front cover. there is a hole in the cover that holds the shaft. you have to take down the oil pump on the bottom of the motor and the shaft falls right out. 4 12 mm bolts. important to remember which bolt went where cause they are different lengths. you then have to reset the timing. post back when you get to this point. Plus there is a bolt behind the oil pump too. Quote Link to comment Share on other sites More sharing options...
David K Posted July 13, 2002 Share Posted July 13, 2002 why yes sir there is. it shall be a little 10mm bastard! Quote Link to comment Share on other sites More sharing options...
Guest bang847 Posted July 13, 2002 Share Posted July 13, 2002 DOH!!!!! Quote Link to comment Share on other sites More sharing options...
David K Posted July 14, 2002 Share Posted July 14, 2002 so you got it off? lol Quote Link to comment Share on other sites More sharing options...
Guest bang847 Posted July 15, 2002 Share Posted July 15, 2002 finally i got it out!! I even put the head back on already too!! it was that little 10mm bastard behind the oil pump... Quote Link to comment Share on other sites More sharing options...
Guest bang847 Posted July 15, 2002 Share Posted July 15, 2002 yeah i might get evicted too .... yeah... sooner the better... Quote Link to comment Share on other sites More sharing options...
Guest bang847 Posted July 15, 2002 Share Posted July 15, 2002 david,, give me a call asap... you got my number Quote Link to comment Share on other sites More sharing options...
David K Posted July 16, 2002 Share Posted July 16, 2002 oh oh, you need the carbs back realllly soon i presume. Quote Link to comment Share on other sites More sharing options...
