inZane 240 Posted October 20, 2013 Share Posted October 20, 2013 (edited) Im at a loss. Car loses all electrical power, including ignition system, at low RPM acceleration and turns.The voltage gauge remains steady at 14 volts during power cut, so something at or after the fusebox is causeing the problem. Car is a 72 w/MSD ignition, Internally regulated alternator, Blade type fuse box, Voltage gauge. I started having the problem after I installed a new external fuel pump. I don't know if it is a coincidence or not because I had not driven the car for a few months prior to the fuel pump install. Anyone else have this problem before that can suggest some places I should be checking. I dont want to trace wires if I don't have to Thanks! Edited October 20, 2013 by inZane 240 Quote Link to comment Share on other sites More sharing options...
dexter72 Posted October 20, 2013 Share Posted October 20, 2013 I would start checking alll the connections under the hood first. Battery and at the alternator. Tighten and clean them. Then the under hood harness. Quote Link to comment Share on other sites More sharing options...
Sideways Posted October 20, 2013 Share Posted October 20, 2013 What he said Quote Link to comment Share on other sites More sharing options...
inZane 240 Posted October 25, 2013 Author Share Posted October 25, 2013 Sourced it to a bad splice after the fuse box. Thanks for the suggestions. Quote Link to comment Share on other sites More sharing options...
