LT1 t56 clutch bleed?
Here is an interesting problem.
http://performanceworks1.com/ls1_clutch_bleeding.htm
There is no bleeder on the slave cylinder for the 96 camaro/firebird.
The website above is the only source that gives a solution. I really find it hard to believe that the system is self bleeding.
I think I am gonna gravity bleed the line to the cylinder and then attempt to follow these instructions and see how it goes. It seems dumb to not have a bleeder on there for servicing.
just attach the hose from the master cylinder down to the slave cylinder but dont install the slave cylinder to the transmission yet. Fill the master cylinder with the correct dot fluid then slowly press the rod on the slave cylinder all the way until it bottoms out and slowly let it extend all the way back out, repeat until you have no bubbles. You may let it sit a few to allow any trapped air to rise, once its bled it will self bleed from there
