Factory cam specs?
Connor280ZX
There's a pretty long thread on the forum somewhere about measuring cam specs. that suggest the numbers on atlanticz may not be completely correct.  The FSM might get you closer (Engine Mechanical chapter), but there's some question about those numbers also.  For increased performance purposes though, most people seem to consider the stock cams as essentially the same, compared to what you can have done by a specialist.
The biggest issue with the P90 head is probably whether or not it's hydraulic or mechanical lash adjustment.
  • 4 weeks later...
