74 260Z Interior Door Glass Picture?
ESP-OFF
Hey guys, I’m slowly putting my Z back together after taking it apart over a year ago to do body work and paint.  I put the door glasses back in and I seem to be missing like a slide bolt or something that goes on the bottom right of the door glass frame to keep the door glass from falling forward and out of the back of the track.  I’m attaching a pic of what I’m talking about and hopefully someone has a pic that can help me. I’ve looked for a pic but had no luck. Thanks.  Also attached a pic of my 2jz-gte 260z project :)
What keeps the window from sliding backward (or forward) and out of the tracks is the verticle guide in the forward part of the door.  There's nothing at the rear-end of the window or it's frame that will help you in that regard IIRC.  There's also a short horizontal guide (5 or 6 inches long, 2 studs attached, just forward of mid-door) that needs to be in place.  Take a pic of you entire door (focused if possible :icon12: ) and let's see if you have all the parts you need...  The FSM should have fairly good diagrams of how all that goes together.
i understand what your talking about. I have the front guide in and i also have what is called the 3rd arm adjustment in as well.  I'm pretty sure its probably just a bolt with a washer on it that goes into the rear of the upright track to keep it from falling forward and coming out of the the front track and out of the rear on rolling it up. i remeber taking a nut lose that was very thin from the second picture where the hole is. I wish someone on this site had there door panel off and could show me exactly what i miss placed
