cam choices..need advice.
Guest bigjim240z
Guest bigjim240z
ok..i used to run an l26 with e88 head and a big isky cam, downdraft webbers and a header. the car ran quite well...now i have an l28..with an n42 head. im gona get the same cam as i had in the other engine..but i have a little problem, the n42 uses a drilled cam and the e88 used a non drilled cam. how can i use a non drilled cam on a nn42 head? is it possible to just use the e88 cam towers and oil bar with a non drilled cam on the n42?..the drilled cams are way high priced and i can have a non drilled stock cam reground to any specs i want fo 75 bucks. any help is appreciated..thanks jim
