stretchnuts Posted December 4, 2013 Share Posted December 4, 2013 Just got my 77 with 83zxt swap running again on ms1v3. Car will will start with a little throttle, but wont idle, even after warm up enrichments are done. Car revs just fine. Brake pedal was on the floor when I started so I pumped them up (need to be bled probably too), and while im pumping up the brakes the car idles fine. Sooo I immediately thought vacuum leak from brake booster. I pulled off the line and I had the wife start and keep the car running while I put my finger over the metal line thinking I could isolate it. Car still wanted to die at idle. I know it has to be vacuum leak but not sure from where. Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted December 7, 2013 Share Posted December 7, 2013 You may want to request this thread to be moved to the megasquirt subform. You may receive more feedback there. Also upload your msq file and maybe a datalog. Quote Link to comment Share on other sites More sharing options...
