Guest datsun75 Posted November 5, 2001 Share Posted November 5, 2001 I just received the Edelbrock Performer intake. I meant to buy the Edelbrock Performer "RPM". What do you all prefer? or what works best with: Chevy standard bore 350 w/ Holley 600cfm 4 barrel, double hump 64cc heads, headers, 270Adv. duration .470/.470 comp cam. Should I stay with performer or will the RPM intake make much difference? I have heard the RPM intake is very close to the early 70 Z28 intakes. I hope my 75 Z hauls with this setup. Thanks for any input guys! Quote Link to comment Share on other sites More sharing options...
Tim240z Posted November 5, 2001 Share Posted November 5, 2001 With the setup you describe, I very much doubt that you'll notice any difference. Not worth the hassle of returning/exchanging it IMO. Tim Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 5, 2001 Share Posted November 5, 2001 It'll probably work ok with your setup, the RPM might have given you more future expansion possibilities if you wanted to go with say more cam or like the RPM heads or something. But it should probably be fine with your setup IMHO. The RPM I believe is just set up for a bit more flow at higher RPM (hence the name... ). Regards, Lone Quote Link to comment Share on other sites More sharing options...
Guest datsun75 Posted November 5, 2001 Share Posted November 5, 2001 Okay, thanks I just hope Im not cutting myself short on HP by not buying a Comp Magnum 280 or 292 cam. It's all in learning I suppose. Im just critical. I know the Double hump heads I bought have been ported for better flow so I suppose Im matching things up okay with the 270 cam. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 6, 2001 Share Posted November 6, 2001 The 270 should make a nice street cam IMHO, you'll like it I think. I should think (and this is purely a educated guess) 330-350 hp should be achievable, perhaps more depending on finished compression ratio. Regards, Lone Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 6, 2001 Share Posted November 6, 2001 I would definitley go for the RPM. I fyou stick with the regular one you will hit the glass ceiling sooner. Given the fact that most of the people hear end up changing their setup multiple times through the life of the Z I would not sell yourself short. I almost did it. I would have my car running and driving right now if I didn't get horsepower greedy. It doesn't cost that much more to go just a little bigger. When I get done by around April I am sure to be much happier and a crap load faster. All you have to remember is to go bigger but be realistic. Jake Quote Link to comment Share on other sites More sharing options...
DavyZ Posted November 6, 2001 Share Posted November 6, 2001 With your current setup, the Performer will do very nicely. I have to echo on what Lone said, that you have "more potential" in the future to expand your horsepower capabilities if you go with the RPM manifold. I have to tell you, you will probably not recognize any real differences between manifolds with your current setup. There is also an outside possibility that the Performer may have a little bit better off-the-line snap to it with your current setup. I think you will be happy This is all IMO BTW. Davy Quote Link to comment Share on other sites More sharing options...
