ElCimino Posted January 22, 2014 Share Posted January 22, 2014 In the process of upgrading my 240z to electronic ignition. I found a used 280zx distributor with the e12-80 module and purchased a MSD blaster coil part #8222. I have a wiring diagram from atlanticz.ca. I think I had read while searching this topic that some coils still need a ballast resistor in the positive line or the 450v can fry the module or the tach. Can anyone confirm this? The module on the outside of the distributor says e12-80 and 12v. Any information is appreciated. I apologize in advance if this information is listed in another forum and I have not found it yet. Chris Quote Link to comment Share on other sites More sharing options...
NewZed Posted January 22, 2014 Share Posted January 22, 2014 Just make sure the primary circuit resistance (+ to - terminals) of the new coil matches the resistance of the original ZX coil and you should be fine. Quote Link to comment Share on other sites More sharing options...
ElCimino Posted January 22, 2014 Author Share Posted January 22, 2014 Thanks NewZed. I got everything hooked up however the battery is completely dead. I'm charging that now and will try starting and adjusting the distributor then. Thanks for the information! Quote Link to comment Share on other sites More sharing options...
Stresspuppy Posted February 3, 2014 Share Posted February 3, 2014 How is it working? I have a similar setup and things work great, but the tach is off quite a bit. I'm trying to figure out how to get that right, but not having any luck. Does anyone have any ideas with this setup (280zx dizzy with 12-80 using a fairly stock coil, no resistor)? Thanks. Quote Link to comment Share on other sites More sharing options...
beermanpete Posted February 4, 2014 Share Posted February 4, 2014 The early Z tach has a calibration adjustment. You can reach it through a small hole in the back of the tach housing with a small flat-blade screwdriver. Quote Link to comment Share on other sites More sharing options...
