turbo
My orange 240z has a L24 that is turboed. Stuck a P90 head on it. Compression isn't any lower than stock L28ET compression it's 7.54:1.
My turbo is water cooled, stock 280zxt turbine/housing, with a t04b .60 A/R and V trim compressor.
I have a cheapo starion intercooler on the car and my engine management system is based off of a 280zx turbo setup, which I played around with, not because of the L24 being there, just because... I'm different.
I'm using the turbo oil pump, and turbo head bolts (they are stronger). Just a note, the L28ET's piston/ring config is a little different, and are better suited for turbo application, but the L24 seems to be hanging together just fine.
