UPDATE(75 280z)60 amp Alt swap that has been done without the wiring swap?
You have a short somewhere.  All you can do is check wires.  Check the alternator B post for continuity to ground with a meter.  You might have a bad alternator.
Also make sure that you don't have other things connected to the B post.  Like the black ground wire.
Edited by NewZed
So I just wanted to say thanks to NewZed and Aliasct for the replies and the help with this swap!
So only issue I have now is that my dash lights and head lights flicker and the Volt Meter needle starts bouncing around... This happens when driving and the engine is Reving....now could this be from the fusible links? I read one post and sounds like it could be a ton of other things too...
If it's the fusible links I would like to replace it with this one...has anyone had experience with this brand??.
http://gadgetpro.stores.yahoo.net/st4dimafubl.html
You guys are making things complicated.  If Zman has the wires connected correctly, the ZX alternator should work fine.  If they're not connected correctly, he'll just be connecting the 240SX alternator incorrectly also.  They both work on the same principles, the wires are the same only the appearance has changed.
If you want to see the plug-style for an alternator go to the auto parts sites online and pull some up.  They have some good pictures.  Some show the pin-out for the plug also.  Switching alternators won't have any effect though unless the ZX alternator in there now is bad.
And here's a helpful article from RockAuto.com - http://www.onlinetechhelp.com/installguides/Alt%20Inst%20Inst%20(1).pdf  Almost every alternator listing has a little article attached.
