cheechq Posted February 18, 2014 Share Posted February 18, 2014 My 77 280Z has a 5 lug hub with 5x114.3 pattern. The conversion keeps the same geometry for wheels as a stock setup except for bigger bore needed on wheel (at least 72mm) and 5 lugs instead of 4 lugs. It is a techno toys tuning setup that includes brakes. I have large Wilwood brake calipers on the front that require 7/8'' of clearance and caliper height is 6 3/4''. In other words, most wheels that fit a stock S30 would fit my setup if the wheels are 5 lug instead of 4 lug and I removed my brake calipers. Can anyone recommend low cost wheels for the front? Quote Link to comment Share on other sites More sharing options...
Phantom Posted February 20, 2014 Share Posted February 20, 2014 Go to www.Tirerack.com and see what they have. You're going to want anywhere for a 0 to a +10mm offset depending on your suspension and tires you want to run. You will need at least a 16" wheel for those calipers. Quote Link to comment Share on other sites More sharing options...
