280zxNick Posted February 19, 2014 Share Posted February 19, 2014 So I have an aftermarket sway bar on the front with poly bushings but the 2 brackets in the middle of the sway bar have broken and no parts store/ junk yard has any and I was wondering if anyone knows where they can be found. Thanks in advance Quote Link to comment Share on other sites More sharing options...
nismoluv Posted February 19, 2014 Share Posted February 19, 2014 I know where you can get them in a kit, Im not sure if you can by them separate though... number three? http://www.blackdragonauto.com/icatalog/zr/full.aspx?Page=47 Quote Link to comment Share on other sites More sharing options...
280zxNick Posted February 19, 2014 Author Share Posted February 19, 2014 (edited) Yep that the right one thank you Edited February 19, 2014 by 280zxNick Quote Link to comment Share on other sites More sharing options...
SHADY280 Posted March 9, 2014 Share Posted March 9, 2014 The aftermarket sway bar uses bigger (or should have come with) bigger brackets for it. What always happens to them is they break and you need to make new ones out of thicker steel or a block of aluminum. Search should yield some good options around here, what I did was get a shop to bend a piece of 3/16" flatbar with tabs on either side and recreate the bracket. Hasn't broken since!!! Quote Link to comment Share on other sites More sharing options...
