turbobluestreak Posted October 22, 2002 Share Posted October 22, 2002 I'm been looking to find someone who sells sets of hyperuticic pistons for a custom stroker project. I want to use the LD28 crank and 240z rods, I want the piston to be 88mm with a wrist pin height of .005 below the top of the deck. I've been looking and looking and can only find forged custom pistons, I've been looking at wiseco's custom set for only 630 with everything but would like a cheaper piston so I can spend money else where. Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted October 22, 2002 Share Posted October 22, 2002 No one makes those for a Z engine that I am aware of. Your best bet would be to run a high silicon content forged, if na, and perhaps the same if you are turbocharged, although they will not take the punishment a low silicon forged will take. High silicon lets you run tighter cylinder wall clearances, which makes the engine quieter, and helps with oil consumption. Quote Link to comment Share on other sites More sharing options...
