****Needing Misc. l28et Parts****
HarveyZ
I have an 81 l28et and I am needing a few random parts.
Turbo oil return hose and oil feed line
Fuel pump block off plate
Oil cooler lines
Upper and lower thermostat housing (needing both on each side of the motor)
Slave cylinder
440cc injectors and fuel rail
T3/T04 Hybrid turbo or larger
Aftermarket fuel pump and FPR
Throttle linkage on the firewall (and the rod that goes from firewall to the intake throttle linkage)
Oil cooler lines
Slave cylinder
Did you need mean the block the oil return line connects to from the turbo and had the oil pressure unit that screws In it?
I have a new t3/t4 that I have not used. It was for a tractor. I don't recall the exact specs but I could do more research if your interested.
