dylanh Posted April 1, 2014 Share Posted April 1, 2014 Hi I changed my headgasket awhile back and I didn't make the chain wedge correctly and the tensioner came out I believe so my question is how do you pull off the front timing cover to fix this? It looks like pull off waterpump, the crank pulley, and then all remaining bolts including the two at the bottom on the oilpan is this correct? Is there any trick to do this without pulling off the front cover? The chain didn't jump teeth I believe. Also I'm located in Lake Charles, LA and if someone is nearby and willing to help I will pay for your time. Thanks! Quote Link to comment Share on other sites More sharing options...
Watson Posted April 1, 2014 Share Posted April 1, 2014 Don't forgot the oil pump. You'll need to remove that to gain access to a bolt on the timing cover. Be extra careful (liberal use of PB Blaster) not the break the waterpump and timing cover bolts off into the block. Ask me why I know this... Quote Link to comment Share on other sites More sharing options...
