help with starter
I was wondering who on this forum uses a gear reduction starter on Z's that dont use them stock. I replaced mine with a gear reduction starter from my friends 280zxt and it worked ok untill just the other day. I turned the key and the engine turned over for less than 1 second and the starter just spooled up. I then switched back to my stock 260 starter and it only grinds. Are both starters bad or is my car unable to use a gear reduction starter.
Ps: Both starters worked fine until I switched them.
Thankz James
provided your battery cables are tight and in good condition ( no swelling or corrosion ). It sounds like you have two used parts with similar problems. What you need is a rebuilt/remanufactured one. I highly reccomend the gear reduction variety. I have used one for years on my 260 it works great and it weighs less.
