Horn doesnt work after nardi wheel install
Rob L
Hey guys i just installed a works bell quick release with a nardi wheel and a boss hub adapter .....before the install the horn worked ....after install i plugged the wires in properly ...triple checked them ...but the horn doesnt work now.
Anybody run into this before ...any ideas what might have caused this ?....any help would be appreciated as a functioning horn is needed.....Thanks.
It's most likely the little armature at the back of the hub that is not making contact with the grounding ring.  Grant steering wheels also have this problem.  Mine would work for a week and then stop working.  I finally grew tired of it and wired up my horn to the windshield washer button on the end of the combo stalk.  It's spring loaded just like the horn button and just as easy to push when needed.
well i will be able to look at that this weekend ......another thing i jusy ran into is i have the hub adapter plus i added the works bell slim quick release...well with that added the horn button fits but doesnt sit flush up against the wheel .....if all else fails i just might have to rewire it like stated above.
I also just fixed my horn this week. I have a Grant wheel and the ring did not meet up with thehorn wiper. I used some thick copper clad pc fab board. Cut it out to match the ring and fixed it to the assembly. Works like a charm. Hope it helps.
I just put a momo hub on with nrg quick release and Sparco wheel. I had to change a plug to hook to the grounding plate between the hub and the q/r. I also had to loosen the screw holding the wiper and move it in a bit but it hit once I did that. Works great now except that the hub legs aren't in the perfect place for canceling.
