Stuck Fill Bolt on 5-speed , Fill up at reverse switch?
TieFighter88
Gday,
I have an 5-speed on my L28 I want to change the fluid on, however the fill bolt is more stubborn than my wife.
Tried heat , lots of heat, rust penetrant, and more elbow grease than I am comfortable with. I have read about blokes welding bolts on the end, or welding bars to add more leverage on the thing, but when I look at the reverse switch, I wonder if I can fill the trans at that point... The fill bolt and the reverse switch are very close in height, and the switch comes out no problem...
I did search before bugging the forum, tried: transmission bolt, stuck trans bolt, stuck fill bolt, fill bolt, etc etc.
Remove the fill plug.  It takes a lot of leverage sometimes.  Try 2' of pipe on the end of your wrench and make sure the wrench fits tight over or in the fill plug.  Last Z I worked on took 3' of pipe on the end of a breaker bar.  Use anti-sieze when you reinstall it.
