Broken R200 CLSD spring plate
eugene
I broke two adjacent ears off of one of my spring plates installing extra clutches.  So far I haven't been able to source a replacement part.  Any thoughts on just using one spring plate per side.  I plan to make the overall clutch stack measurement match with shims/extra clutches.  I think the progressive action of the diff should be affected, but imagine having the same breakaway would result in similar driveability.  Any good reason not to try this?  I still have the original 2 clutches and spacers, along with the 6 replacement clutches sold by savage42.  I am wondering how much the spring compresses.  I imagine the stack should be a small amount thinner
Thanks, I guess I'm gonna try to make it work with 1 spring plate per side.  I didn't like how tight it was with the 6 clutches, but all I did was measure the clutches and spacers, no testing or shimming was done.  I don't know if it was binding due to incorrect thickness which caused breakage, or if incorrect install caused breakage and resulted in binding.  It was probably the latter!  Thanks for the link.
Yeah, it seems thats the way to go.  I did it at work real quick one day before I went home.  This time I'll do it at home and be more careful.  Might even try and check torque this time.  I'll post back with my results, hopefully soon.  Thanks for the tip.
