EDIS ? CHrysler coil wiring double check
str8pipez
After finding conflicting info I would to know if anyone can verify if I have the wiring from the EDIS module to the Chrysler coil pack connector.
I'm connecting as follows:
#10 EDIS pin (yell/blk) to coil pin #2 (gray/red)
#11 EDIS pin (yell/wht) to coil pin #4 (blue/gray)
#12 EDIS pin (yell/red) to coil pin #1(red/yell)
Green/orange from coil plug to 12+, coil pin #3
I have attached a photo of both plugs.
Thanks in advance.
Here's how I wired mine and it works great.
http://forums.hybridz.org/topic/56438-corrected-wiring-diagrams-for-edis-6-ignition-module/
Also, tie a wire into each driver signal and wire in diodes as shown in this pic for your tach signal. I removed the factory tach resistor and plugged my tach wire into the factory harness with a bullet connector.
Edited by mattb3562
If that is the case, you show EDIS pins 10, 11 and 12 going to pins 1, 2 and 3 on the coil plug, but the coil plug diagram shows #3 as ASD relay and pin #4 (which you show as 12+) as coil driver 2, not 12V as shown in your diagram. What am I missing?
Edited by str8pipez
