240zBoy Posted June 2, 2014 Share Posted June 2, 2014 So my halfhaft is moving in and out of the differential. Not really the halfshaft but rather the flange that the 4 bolts mount to that goes into the differential. That whole unit is moving in and out as if it has broken loose from the differential. Is this flange compression fitted into the differential? Or is there potentially a clip that I did not install when I put it in. When I installed one of the flanges was on the differential and the other had it still stuck to the halfshaft. I slid it in and pounded it then installed but now I have a ton of noise coming from the right rear wheel and the halfshaft is loose from the differential. Quote Link to comment Share on other sites More sharing options...
NewZed Posted June 2, 2014 Share Posted June 2, 2014 R180 uses a bolt. R200 uses a circlip. Labeled drawings in the Prop and Diff chapter, with instructions. Quote Link to comment Share on other sites More sharing options...
240zBoy Posted June 3, 2014 Author Share Posted June 3, 2014 Thanks! I might have to be purchasing a clip then for the one. Time for the real challenge of finding that haha Quote Link to comment Share on other sites More sharing options...
Zeppelin408 Posted November 5, 2014 Share Posted November 5, 2014 Any luck finding the circlips? If so were they easy to install ? Having same problem on a r200 Quote Link to comment Share on other sites More sharing options...
