Guest kcambron Posted November 26, 2002 Share Posted November 26, 2002 I'm going to put a L28 into my 73 240Z and would like some info on what is required concerning electrical changes and fuel requirements. (1) Will I need the fuel tank from a newer car? (2) What electrical components will I need? (3) If mods are made later, will I be able to increase the fuel flow easily? Thanks in advance for your replies! Quote Link to comment Share on other sites More sharing options...
johnc Posted November 26, 2002 Share Posted November 26, 2002 Are you going to run the fuel injection system from the L28 or the carburators from the L24? Quote Link to comment Share on other sites More sharing options...
Guest kcambron Posted November 27, 2002 Share Posted November 27, 2002 I really want to run the fuel injection! Quote Link to comment Share on other sites More sharing options...
Guest bastaad525 Posted December 1, 2002 Share Posted December 1, 2002 If you want to run the EFI, you're gonna need all the EFI components from the donor car, including: intake manifold, throttle body, air flow meter, ecu, wiring harness, sensors, and various other electronic parts. You'll also need the fuel tank and fuel pump from a '75 or later 280z. Quote Link to comment Share on other sites More sharing options...
riverz Posted December 1, 2002 Share Posted December 1, 2002 I have an intake and all the stuff you need. Where do you live? Quote Link to comment Share on other sites More sharing options...
Guest kcambron Posted December 1, 2002 Share Posted December 1, 2002 Thanks, I have all the parts from a 76 EFI donor car. I am just getting a game plan on what I am going to need, It's starting to come together! I have the engine bay harness out and the harness form the drivers side "computer" to the flow sensor. I am still a little unclear as to the next step on the electrical connections under the blower motor. My plan is to install the 280Z harness that goes to the computer and engine bay, then attack the connections under the heater blower! Thanks for the help! Kevin Quote Link to comment Share on other sites More sharing options...
marcus70ZT Posted December 2, 2002 Share Posted December 2, 2002 you will also need a bigger fuel return line if you are running the EFI. the carb line will not flow enough and your fuel pressure will go sky-high causing you to run rich. Quote Link to comment Share on other sites More sharing options...
