10mm vs 12mm ring gear bolts-need advice
RebekahsZ
I just picked up a 3.36 R200 from a 74 260z 2+2 and I will eventually put a CLSD in it. It is not the project of the moment. I currently have (4) 12mm CLSDs I can swap around to my different ratio diffs.
But, there is a 10mm naked CLSD carrier for sale in the classified forum and I don't currently have a 10mm carrier. If I need it, I want to get an offer in on it. If I don't need it for the 3.36, I will let it pass.
To see if I need the 10mm for my early 3.36 R200, I pulled the cover: the ring bolts have 14mm heads on the bolts. I pulled the cover off one of my later 3.54 R200s and the heads on the ring bolts were also 14mm.
QUESTION (finally): does anybody know if the 10mm ring bolts also have 14mm heads? If nobody knows, I need to tear down my 3.36, put the carrier in a vice and impact out a bolt to see. Help with knowledgeable advice. Thanks.
