Guest Anonymous Posted December 5, 2002 Share Posted December 5, 2002 Well, those of you that have been following my previous threads should know what I've done so far. I had to loosen the AFM about 16 notches in order to get it to stop backfiring through the intake manifold and to run right. It runs like a top right now. Today I had to get get the emissions done on it, I passed all tests, including the revving test they do, but I failed the one where it idles. Here is what the readings said: Hydrocarbons are supposed to be 250, mine were 354. Carbon Monoxides are supposed to be 2.00, mine were 6.62. I want to say it's the AFM that's causing the problem but at the same time I want to say those AFM adjustments I made are only covering up another problem. It's apparent that it's running too rich at idle. Any thoughts on this? Could it just be the AFM? I'm headed over to Scottsdale Nissan tonight for the Z club meet, my damn temporary tag expires today. Hopefully those guys can give some insight as well. Thanks for caring. Chris Quote Link to comment Share on other sites More sharing options...
yo2001 Posted December 5, 2002 Share Posted December 5, 2002 loosen the adjustment screw on the side of the AFM. Quote Link to comment Share on other sites More sharing options...
David K Posted December 5, 2002 Share Posted December 5, 2002 yeah give it some more o2 Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 5, 2002 Share Posted December 5, 2002 If I do that it starts backfiring through the intake and it won't rev. So, so frustrated. Chris Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 5, 2002 Share Posted December 5, 2002 To get my 280z to pass emissions in NC I had to do the samething with the air flow meter. Had a bigger cam in the car. For the idle test car had to idle under 1000 rpms. Hydrocarbons were fine above 900 with that cam. I rigged the throttle linkage to hang up just above idle. Maybe that would help you also. Mark Quote Link to comment Share on other sites More sharing options...
yo2001 Posted December 5, 2002 Share Posted December 5, 2002 Race gas, Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 5, 2002 Share Posted December 5, 2002 Okay.. I went to the local Z meeting tonight and spoke with one of the best mechanics, also the one that looked at my car about a year before a bought it. Apparently my car had been sitting for almost 2 years, this mechanic thinks that my fuel tank is clogged.. providing enough pressure but not enough fuel flow. Makes sense. Buddy of mine still thinks it's the AFM that's borked. Even though it runs fine it's apparent that it's running WAY too rich at idle. So, that leaves me with one option. Drain the tank again, go have it dipped in acid and flushed and buy a new AFM. I'm going to replace the fuel pump as well. Any of you guys know where I can get some good deals on those items? Any thoughts? Chris Quote Link to comment Share on other sites More sharing options...
yo2001 Posted December 5, 2002 Share Posted December 5, 2002 I got a spare fuel pump from 78. drop me an email @ yo2001@charter.net Quote Link to comment Share on other sites More sharing options...
David K Posted December 5, 2002 Share Posted December 5, 2002 i will look in the garage for an afm tommorow. what number is on yours? you can have it for free if i have one. early CHRIStmas present hehe. Quote Link to comment Share on other sites More sharing options...
