Guest Anonymous Posted December 12, 2002 Share Posted December 12, 2002 Okay, So I had my tank flushed today as per a Nissan mechanics suggestion. I went ahead and purchased a new fuel pump today as well as this 280z will be my daily driver soon. The fuel tank is still out of the car because I ran out of daylight but I did get the fuel pump installed. I wanted to see if the fuel pump would kick on and hum like it usually does so I connected the battery back up and flipped the key to the on position with my head under the car, I could hear the fuel pump kick on and make almost like a sucking sound, is that normal with open lines and no fuel tank? I'm trying to cover all of my bases before I put the tank back on on my day off on Saturday. I listened for it twice, made the exact same noise both times. Like I said, it clicks on and makes a brief sucking noise, I figured this is because the system isn't pressurized right now. If you could tell me what you think I'd appreciate it. Just want to make sure I am doing this right. Chris Quote Link to comment Share on other sites More sharing options...
JKDGabe Posted December 12, 2002 Share Posted December 12, 2002 That sounds right but you prob. shouldn't run it while dry. That is a major cause of fuel pump failure. Even if there was fuel it will only run for 5 sec before it cuts off again. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 12, 2002 Share Posted December 12, 2002 Yeah, I did it twice. That is GREAT news to hear though, I was out there all day cleaning the undercarriage up, replacing the pump and dropping the tank. I just wanted to make sure the fuel pump is supposed to do that with open lines and no tank before I put the fuel tank back up. Chris Quote Link to comment Share on other sites More sharing options...
