bryand2 Posted July 11, 2014 Share Posted July 11, 2014 Hi guys, I am in the middle of swapping an l28et into my 280z and I am upgrading to the z31 ecu, maf and optical wheel, which are from an 85. The only thing I am still missing is the ecu. My question is, all the faqs on here say 84-86 ecu will work, but from what I understand the 86 injectors are different. Will an 86 ecu work and do they require resistor packs? Quote Link to comment Share on other sites More sharing options...
DuoWing Posted July 11, 2014 Share Posted July 11, 2014 84-87 Turbo ECUs will not require will resistor packs. The 88-89 ECUs will require inline resistors. The 86-89 ECUs all use the smaller Titania resistance based O2 sensor, but for the most part any of the ECUs will run fine without the O2 sensor connected. Quote Link to comment Share on other sites More sharing options...
bryand2 Posted July 12, 2014 Author Share Posted July 12, 2014 thanks duo Quote Link to comment Share on other sites More sharing options...
