415DZ Posted July 11, 2014 Share Posted July 11, 2014 Hey everyone! So I'm not the most mechanically inclined, so please bare with me. I have 1971 240z with a vg30e motor swap done by a previous owner. I want more power out of it and I got a quote to have rebello build it to @300hp. It's not cheap, but it seems like it would be something i really like. I was also thinking of bolting on turbo parts from the vg30et but then I run into compression issues etc. I recently found a 1988 300zx turbo that I can buy and swap the entire motor, tranny, and rear end. Please correct me if I'm wrong, but that car comes with a r200 clsd rear end right? So my question is would the motor just drop in or with there need to be a lot of fabrication like custom mounts and or custom manifolds? Also which ecu would you recommend for such a swap? Just use the stock ecu from the 300zx or go for a mega squirt type system? My goals are a street driver car with decent power that will be reliable and fun to drive. I may occasionally track it but not a big focus. Somewhere around 250hp-300hp is more than enough power. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted July 11, 2014 Share Posted July 11, 2014 (edited) The 88t came with a CLSD from the factory, yes. That's nice to have. The stock Z31 turbo manifolds and/or turbo will not fit on the VG30. The steering rack is in the way. You might be able to use a relocation pipe. There are a couple documented build threads on this site. I've done one of them. I do not recommend spending money on a built NA VG30. For $5000 you will get maybe, maybe 200hp. For that price and perhaps a bit more on a turbo motor you can get custom manifolds and a built motor and make 300-500hp easily. None of the Z31s have 'high' compression by today's standard. It's actually somewhat preferable to get a NA Z31 and do a turbo swap, as the 9:1 ratio works well with mid-range turbos. I do not recommend using the stock ECU. Using Megasquirt will be simpler. Edited July 11, 2014 by BLOZ UP Quote Link to comment Share on other sites More sharing options...
