When switching to megasquirt, what gets unplugged stock wiring wise?
dpuma8
Its an involved process either way. Depening on which engine it is will depend on if you leave out the knock sensor or whatever. The real question is what do you need to hook up, not what gets left out. Look at the diagram. Everh sensor needs to get hooked up on that diagram, except the O2. But a wideband is a must for tuning. Its a whole new ECU, so dont think that if a sensor is on the motor, it needsto be hooked up. Definitely chuck the old MAF in the garbage and either get a newer on like I did (Z32) or go speed density, aka MAP sensor. Dont think that a MAF is a hinderence to tuning, those of us who switched to MAF on the MS love it.
I have everything I need for the Megasquirt side of things which means I have all the sensors, relay board, and labeled wires. I was just wondering about the stock wiring. So just unplug the old ecu and off I go installing Megasquirt?
What worked for me on the Z31s I've megasquirted was reusing some of the stock wiring. This took some time and planning but required less rewiring. On my S30 I opted to use one of the fancy wiring harnesses. Totally worth it, especially since the S30 wiring was really archaic, and a lot of wires were the same color. Also, I didn't have to assemble that damned DB37 which in itself was worth the price.
So, go with rewiring it with the DIY harness. Keep in mind you'll still have to locate the stock ECU power, ground, CAS, etc. wires. You may also have to rewire a relay or two, IIRC. So first wire up what you need, get it running, then you can remove unneeded stuff later.
On my S30, the power is wired straight to the battery and the Sign on signal comes from the fuel pump power wire. I built my own relay board, but the concept is still the same. With the relay board and the DIY harness, all you need in wiring is there. Just remove all of the upper harness and keep the lower harness for the alternator and starter. Run the power wire for the relay board to the starter and find an ign on signal to pull from for the relays. The old wiring can be removed without cutting anything, I would just get it out of the way.
