Meatwad Posted August 5, 2014 Share Posted August 5, 2014 I plan on running flipped truck manifolds for the turbo. I've searched and haven't found much. I know some of you are running truck manifolds and some are running custom turbo manifolds or custom turbo headers. Is there any brand of turbo headers that can actually be bought? Most of the turbo headers I have found are usually for the fbodies. One of my truck manifolds are cracked, so I'm trying to look at my options for exhaust manifold/headers that would work in a front mount turbo LSx S30. Quote Link to comment Share on other sites More sharing options...
mattd428 Posted August 5, 2014 Share Posted August 5, 2014 Mine are obx $600. Quote Link to comment Share on other sites More sharing options...
Meatwad Posted August 5, 2014 Author Share Posted August 5, 2014 Mine are obx $600.Do you have them in the up and forward position or down in forward? Quote Link to comment Share on other sites More sharing options...
mattd428 Posted August 5, 2014 Share Posted August 5, 2014 Up and forward. Quote Link to comment Share on other sites More sharing options...
Meatwad Posted August 5, 2014 Author Share Posted August 5, 2014 Up and forward.Have a picture? Quote Link to comment Share on other sites More sharing options...
mistafosta Posted August 5, 2014 Share Posted August 5, 2014 Down and forward here. Still using camaro alternator mount. Quote Link to comment Share on other sites More sharing options...
mistafosta Posted August 5, 2014 Share Posted August 5, 2014 stock truck manifolds of course. Quote Link to comment Share on other sites More sharing options...
mattd428 Posted August 7, 2014 Share Posted August 7, 2014 http://forums.hybridz.org/topic/114060-time-for-the-53-to-get-some-more-power/page-7 Videos and pics are on that page. Quote Link to comment Share on other sites More sharing options...
thezguy Posted August 7, 2014 Share Posted August 7, 2014 Modified truck manifold here. They are faced up and forward. Quote Link to comment Share on other sites More sharing options...
Meatwad Posted August 7, 2014 Author Share Posted August 7, 2014 Modified truck manifold here. They are faced up and forward.Aren't you on ls1tech with the white z with the CCW's? Also what material of welding wire are you guys using to weld the cast steel onto mild steel? Quote Link to comment Share on other sites More sharing options...
thezguy Posted August 7, 2014 Share Posted August 7, 2014 Yes, that's me. I used a SS flange not mild steel. I used 316L becuase it's what I had lying around. I believe "they" at your suppose to use a nickel based filler but we'll see very soon (will be fired up in the next few weeks) Quote Link to comment Share on other sites More sharing options...
Meatwad Posted August 7, 2014 Author Share Posted August 7, 2014 Yes, that's me. I used a SS flange not mild steel. I used 316L becuase it's what I had lying around. I believe "they" at your suppose to use a nickel based filler but we'll see very soon (will be fired up in the next few weeks) Haha I'm 99medbluebird that sends you pm's every once in a while. Cant wait to see yours fire up! Quote Link to comment Share on other sites More sharing options...
mattd428 Posted August 8, 2014 Share Posted August 8, 2014 Thezguy has no clue what he's doing don't listen to him. Quote Link to comment Share on other sites More sharing options...
thezguy Posted August 8, 2014 Share Posted August 8, 2014 You wish joe dirte Quote Link to comment Share on other sites More sharing options...
thezguy Posted August 8, 2014 Share Posted August 8, 2014 (edited) MeatWad, No worries man that's what forums are for! I still need to get the offset for the front rims for you. I'll call john at CCW tomorrow. Edited August 8, 2014 by thezguy Quote Link to comment Share on other sites More sharing options...
Meatwad Posted August 9, 2014 Author Share Posted August 9, 2014 MeatWad, No worries man that's what forums are for! I still need to get the offset for the front rims for you. I'll call john at CCW tomorrow.No rush bud! Quote Link to comment Share on other sites More sharing options...
Slow78z Posted August 9, 2014 Share Posted August 9, 2014 (edited) I tig welded mild steel tube onto the cast steel manifold using mild filler rod for my passengers side mani. So far its holding up but if I do it again I'll go with the nickel rod. The setup has roughly 2000 miles on it so far. Edited August 9, 2014 by Slow78z Quote Link to comment Share on other sites More sharing options...
Meatwad Posted August 9, 2014 Author Share Posted August 9, 2014 I tig welded mild steel tube onto the cast steel manifold using mild filler rod for my passengers side mani. So far its holding up but if I do it again I'll go with the nickel rod. The setup has roughly 2000 miles on it so far. That's nice! I like it! Quote Link to comment Share on other sites More sharing options...
Slow78z Posted August 19, 2014 Share Posted August 19, 2014 That's nice! I like it! Thanks! Quote Link to comment Share on other sites More sharing options...
Meatwad Posted August 24, 2014 Author Share Posted August 24, 2014 (edited) So I found these JBA shorty headers that are for trucks and is supposed to be a direct replacement on the trucks. I wonder if these would work if I removed the 3 bolt flanges and welded a v band to them. The tube size is 1-5/8in which I think is small for a 6.0l. Opinions on this? Edited August 24, 2014 by Meatwad Quote Link to comment Share on other sites More sharing options...
