fl327 Posted January 8, 2003 Share Posted January 8, 2003 run it. 142 is max. minimum compression in factory service manual from which i am quoting is 100psi. if you get 120 all the way across, youre good to go, i would pop off the oil pan and check the bearings before you go, and saddle up! Quote Link to comment Share on other sites More sharing options...
280z-racer Posted January 8, 2003 Author Share Posted January 8, 2003 i pulled all of the sensors i could find with the engine and the main EFI harness as well as ECU and AFM, so am i pretty good to go for the swap?? Quote Link to comment Share on other sites More sharing options...
280z-racer Posted January 8, 2003 Author Share Posted January 8, 2003 i got an l28et and ran a compression check and it had about 120 psi across all cylinders. is this normal. i really do not want to tear down this motor. Quote Link to comment Share on other sites More sharing options...
