Tedr03 Posted August 22, 2014 Share Posted August 22, 2014 So after researching the injector sticky, it seems like it was a safe bet to buy some precision injectors from a guy who has a 7mgte. According to the sticker, they can be fitted to the l28 intake manifold. Here is the problem, the oring on the bottom that goes to the manifold I thought once removed they would fit. The injectors have a conical shape on the end where the oring was and is about 1mm to big to slide where the stock pintle fits. I'm getting frustrated and am needing to know if there's any way to make these work. I know I can get the pallnet for the feed at the top, but what about to the manifold. Can you redrill the manifold to make these fit? Any help appreciated Pics Quote Link to comment Share on other sites More sharing options...
Tony D Posted August 22, 2014 Share Posted August 22, 2014 Absolutely---there is a thread about re drilling. I had a stepped reamer made to pilot in the stock bore, and then go in straight while renaming the hole out to the size necessary. Quote Link to comment Share on other sites More sharing options...
dexter72 Posted August 22, 2014 Share Posted August 22, 2014 You may be able to buy the stepper drill bits from a harbor freight, if you have them in your area. 3 different ones come in the package. Cheap costs also. Quote Link to comment Share on other sites More sharing options...
Tedr03 Posted August 22, 2014 Author Share Posted August 22, 2014 Thanks guys! That makes me feel better Quote Link to comment Share on other sites More sharing options...
